Both the low and high beams are located in the outside headlight housing. It appears the inside headlight housing is empty, ie non functioning. Is this blank location provided for higher output lights required in Europe? And if so, has anyone upgraded to this configuration?
I bring this up because this was the case on my C5 Corvette. Switching to the European replacements was extrodinary!! If I remember correctly, low beams went from 85 watts to 245 watts. The highs had a similar increase but I don't remember the numbers. Yes they were illegal, but it sure made night driving at speed safer.
Could someone outside the USA please check their head lights and confirm if the inside ones work. Thanks in advance for your help.
