1 - 20 of 42 Posts
Trying to figure out what this clunk is...
What i replaced so far: Struts, All bump stops, lower control arms (thrust and the other one), stabilizer link (sway bar link?), brake pads and rotors...
It sounds like something is very loose... No shaking or vibrating or pulling on normal highway speeds. Cobble stone streets like this one in the video replicate the clunk the most. I couldn't replicate the sound while the car was jacked up... Help!
https://youtu.be/lv4lylCPbXQ
What was that?
My strut bushings did a similar noise to what i hear from inside the car. When you record from outside, the sound is harder to distinguish.
Hard to tell but have you ever replaced your swaybar drop links? Just did ours at 70k. Clunk was quite irritating.
Resident Curmudgeon
I fcuking hate chasing suspension noises...
sway bar links would be first.
Resident Curmudgeon
Struts, bump stops, lower control arms (thrust and the other one), stabilizer link (sway bar link?), brake pads and rotors...
does this mean YOU ALREADY REPLACED THOSE ITEMS?????
Discussion Starter #7
Shoot me. Looks like that part got deleted...yes, those parts have been replaced...
Take a look at the top of your Struts in the engine bay; see if there are browny dust looking particles (like Bread crumbs) there.
I had similar clunky noise when my Strut Cushions / Bump Stops went bad.
Discussion Starter #10
I've replaced those already
Is there any change in sound or intensity of the clunk if the brake pedal is partially depressed while in motion? Just trying to rule out loose Brake Caliper components.
Is it possible that this is not suspension related and that it is something bouncing around under the microfilmer covers? Grates there are big enough to let a bolt in. I have found nuts and small caps in there. I would think it could sound similar. It is metal down there.
Discussion Starter #15
That was my first thought...My rotors were causing a little vibration at high speed braking, so ended up changing them and checking out if the calipers were loose. Buy they're not.
Discussion Starter #16
What are microfilmer covers? I doubt it's a bolt, sounds something bigger. If it's a tool left somewhere, the sound would be moving around and not constantly the same...
I wish it was that easy.
Resident Curmudgeon
did you rebuild the strut, all new rubber? or just a new damper?
It doesnt sound like underhood plastic. The brake backing plate is lite guage, it would be tinnier.....IMO
Discussion Starter #19
replaced with brand new Sachs struts using all new BMW bump stops ( those yellow things). It sounds like a loose caliper, but I've triple checked that already...
Resident Curmudgeon
The "strut" is the whole assembly.
"bumo stops" are almost NEVER 'used'.
There are maybe 6-8 OTHER parts in a strut besides the damper part....
Youve carefully looked at the left strut for cracks, looseness, misplaced rubber spring seats, etc? And the top 3 bolts are tight holdig it to the strut tower?
1 - 20 of 42 Posts
