1 - 5 of 5 Posts
What is it for and how it works - the valley pan (top cover)
For example in the N62 V8
it is 1 and 2 and as I understand it, one of the pump outputs enters here with a thick pipe, but then, it flows out somewhere?
PS or the view as below - is it the effect of leakage of the gasket in this thick pipe in which the coolant is
the coolant pipe flows from back of engine to water pump or vice verse, the cover over it keeps coolant in, this is where the heads get fed coolant I think. will see if I can dig up document.
Schematic Parallel Slope Engineering Font
Rectangle Line Font Parallel Slope
Sleeve Font Terrestrial plant Screenshot Bag
search n62 overview and you will find the doc
1 - 5 of 5 Posts
