1 - 7 of 7 Posts
i was looking around, and i saw that some people use ATF DEXRON III? So i was hesitant to buy normal power steering fluid from the auto store...i heard of someone using super blue brake fluid in there too? possible? what should i put in..? thanks
Yaofeng
I suggest you double check the application. My 95 525i uses ATF. My 540i uses Pentosin. But under the Pentosin label on the PS fluid reservoir it says ATF. I can just imagine someone who inherited a 540 with the Pentosin label removed add ATF to the reservoir and damage the power steering.
1 - 7 of 7 Posts
