1 - 17 of 17 Posts
Well i was gonna do my detailed cleaning for this summer and i was wondering what kind of wax is recommended on the bmw paint to remove swirl marks?
Thanx
I praise Menzerna products, but they require some skill. Zaino or Adam's Polishes are good for a novice.
Wax will not remove swirl marks. You will need to polish the car, preferably with a mechanical random orbital to remove the swirl marks. Check out Griot's Garage web site for info on polishing and waxing (and claying) you car.
Ditto- I have been quite happy with Griot's products.
Thanx
As others stated, wax will only temporarily fill in the swirls--you need to polish to remove them. My wax of choice is One Grand Blitz.
You should check out the detailing sub-forum--lots of info there.
I've read a lot about this in these forums and there are many opinions. I used Turtle Wax Carnauba Car Wax T-6 based upon Consumer Reports testing last Fall. I've had excellent results with water still beading up nicely after the Winter and I'm still amazed at the deep shine after I wash the car.
I use Turtle Wax 1 Step Wax & Dry T-9 for touch ups if I have to remove some stuborn dirt or bugs. I've found that Simple Green works well but also removes some wax. I use Lestoil, full strength, on the wheels when needed but PS2 during normal cleaning.
Try Rejex....easy on, easy off. The only downside is its 12 hour curing duration after its been applied.
Does anyone have a recommended wax for Carbon Black paint? Car is only 2 weeks old, but looks as if it's driven through a few swarms of locusts.
Just as I begin thinking about owning a black car again I'm reminded why not to :rofl: Don't mean to be poking fun at you -- I can relate!
I've had very good luck with Zaino products on my black and silver cars.
They have a website you can poke around on. Just google Zaino Brothers.
I would also recommend zaino - just google it like stated above. Gave my car great results and its very reasonably priced.
I just started using Zaino. It was a new concept to me, a polymer rather than a wax. I am sold on Zaino. Being a polymer not a wax, you can get multi layers and depth I hadn't seen with wax. I now use the gloss enhancer/detailer between washes and it stays cleaner longer. It also has anti static and UV protection. This is a fine example of the use of Zaino, but not my car. It was actually this post that got me to try Zaino. :thumbup:
http://www.bimmerfest.com/forums/showthread.php?t=211058
dj
3 pedals only!
I use Klasse AIO and SG. It's also a polymer, similar to Zaino.
1 - 17 of 17 Posts
