1 - 9 of 9 Posts
JETPILOT10
Guys,
I need some help. I have a 2000 540I Sport with Steptronic slush box. What type tool and size is required to remove the fluid service plug on the 5HP24 (A5S 440Z) transmission? It looks like a T50 Torx bit, but I tried removing mine yesterday and it appears like the T50 torx bit is going to strip the grip points inside the head of the bolt. I was wondering if there was another style of torx bit that has wider, flatter points. Its hard to get a clear view of the bolt that needs to be removed. Not sure if the last place that did the Inspection 2 over tightened it or what but I damn sure don't want to strip the grip points in the bolt.
Any suggestions?
Dave
I'm pretty sure its a hex (allen) bit and the size is probably 14mm. It's been a while since I've changed my fluid but I know it is a hex and not torx.
JETPILOT10
Discussion Starter · #3 ·
Hex Allen Wrench
Yes, it is indeed suppossed to be a Hex key, but unfortunately for me, some A hole from the last shop that did the Inspection 2 has stripped the damn hole for the Hex key. I am screwed as I don't see anyway to get the damn plug out. The only thing I can think of at this point in time is dropping the pan, then drilling a hole all the way through the plug and using a bolt extractor to get it out of the transmission case.
Anyone have other ideas on how to get the Filler plug out of the case?
Dave
Hex Allen Wrench
Dave
I cant find a trnsmission filler plug for my 95 325i automatic 17mm only drain plugs are they the same size ? that would explain it.
‘89 325i, ‘98 528i, ‘99 528i, ‘03 325i
My e30 and e46 are both 14mm hex/Allen plugs if I remember right. My e39 looks to be the same but I haven’t actually done it yet. You can buy a 3 socket set at Oreilly that has a 14, 17, 19mm Allen head with 1/2” drive. I also have a bunch of 14’s in the hand wrench style because I work on medical equipment. Take a standard hand 14mm Allen wrench and cut off 1/2” from the short end so that it’s “stubby”. Works great to break the plug free and do it by hand the rest of the way.
Also, if you order the MTL/ATF service kit from FCP they include new plugs/seals. Makes things easier.
2001 BMW E39 540i Automatic Sedan, 195 K miles
On the E39 540i with 5HP24 (AS-440Z) transmission, the drain and the fill plugs of the tranny is an 8 mm Allen hex bit.
And definitely replace the plugs, or at least their thing O-rings, when you service the transmission.
Ah! I've been here before with an old Volvo m46 transmission. You have a welder? Know some one who dose? Weld a bolt into the plug, let it cool, remove your damaged plug and replace it with a new one or do as I did and run it that way for 10+years
Yep, you can weld that 8 mm Allen socket in the stripped hole of the plug. Then unscrew the plug, and throw away the socket and welded plug. Replace the plug.
1 - 9 of 9 Posts
