Hmmmm.... no funds for diagnosis? I thought diagnosis was free?
Anyway, no funds are still a problem because the solution is most likely to replace the entire cooling system anyway.
It's what the rest of us did when it happened to us (and, trust me, it happens to everbody here).
Here's more information on overheating ...
- What to look for when your KTMP (
1) or coolant temperature gauge indicates overheating (
1) (
2) (
3) (
4) (
5) (
6) (
7) (
8) (
9) (
10) (
11) & what to look for in a perfectly normal E39 cooling system (
1) & a picture of every failed part in the cooling system (
1) & various techniques to properly bleed (
1) (
2) (
3) & refill (
1) & drain (
1) (
2) & flush (
1) & what coolant to use (
1) & what parts to replace (
1) (
2) & how to retrofit brass bleeder screws (
1) (
2) & what special tools to make or buy (
1) & how to tell how old your cooling system is
(1) (
2) & how to test the cooling system auxiliary electrical fan (
1) (
2) (
3) (
4) & a DIY for replacing the auxilliary fan (
1) (
2) (
3) & the infamous fuse 75 (
1) & the aux fan relay (
1) & how to diagnose lack of HVAC/IHKA heater core heat with cooling system (auxiliary pump) at idle (
1) & a Behr radiator and Behr/Heat expansion tank autopsy (
1) (
2) & request for another Behr surge tank autopsy (
1) & why new made-in-China Behr/Hella expansion tanks are DOA (
1) & E39 Fan shroud removal DIY (
Besian) (
M54) & some of the better cooling system DIYs (
cn90 1997-1998 M54TU) (
cn90 V8) (
aioros '99-03 M54) (
Ågent99 '01 530i) (
pelican 3-series) (
bluebee M54B25) & tricks to replace the fan clutch nut (
1) & lower-hose thermoswitch o-ring (
1) & to non-destructively remove the heater hoses (
1) or radiator nipple (
1) or expansion tank nipple (
1) (
2) or Oetiker clamp (
1) or misplaced thermostat wiring loom (
1) or broken bleeder screw (
1) & modifying the cooling system pressure cap (
1), or using propanol-based zero-pressure fluids like NPG+ (
1) (
2) (
3) (
4) (
5) or all-aluminum cooling system parts by Zionsville (
1) (
2) (
3) aluminum radiators & what happens if you drive one mile too far with an overheated BMW cooling system (
1).
I am very mechanicly inclined I just don't have the funds for the diagnosis
