1 - 14 of 14 Posts
Double Bimmers
I want to bleed my brakes, any idea where I can find some tubing with a 4mm center… You know the tubing to attach to the bleeder value so I am transfer the old brake fluid to a container without making a mess.
Double Bimmers
Discussion Starter #3
Raffi said:
Home Depot (or other home improvement store), plumbing department.
Thanks, I have no clue.:thumbup:
What is the normal use for this type of tubing?
King of Rear Clunks
Pet store; fish tank tubing.
Rest in peace, Coach
Think very small gerbils. :dunno:
I have no idea, but that's where I got my tubes as well. you might want to get something flexible AND slightly smaller than the bleeder nipple so that it'll slip over and form a nice seal.
You may also want to consider picking up a "Mityvac" hand operated vaccuum pump to bleed the brakes with. The kit I have comes with tubing and adapters to fit over many brake bleeder nipples. It's also handy for sucking out excess brake fluid.
These pumps are available at JC Whitney as well as other places.
I bought my mine at home depot.
If you want help bleeding things out, I'd be happy to. :)
Speed Bump
Pick up about 3 feet of 3/16" ID (5/16" OD I think) clear vinyl tubing at a hardware store or home center. That size has worked well on BMW calipers from my 2002 all the way to my E46 as well as a buddy's Mustang.
Ed
My first posting here...
And I thought I start out well to build good karma. I'm a regular at bimmerforums.com and thought I'd check y'all out.
For very detailed instructions on building a brake bleeder, see...
http://www.apexcone.com/Bleeder/bleeder.html
Works like a charm - just used it Saturday night on mine.
So anyways, hello to everyone and good luck.
Ed
1 - 14 of 14 Posts
