1 - 7 of 7 Posts
Where is the connector to the Control Unit F Cruise control? If it's not by the knies like in My case? I already mounted and connected the clutc-0 switch, cruise-control-switch and the actuator.
1012832
My car was produced in 2001 and sold in Germany.
BMW CCA 1405
1997 BMW Z3 1.9
Where is the connector to the Control Unit F Cruise control? If it's not by the knies like in My case? I already mounted and connected the clutc-0 switch, cruise-control-switch and the actuator....
A couple of posts in this thread indicate that the control and connector may located behind the glove box.
The control (also called module or brain) looks like this:
Discussion Starter #3 (Edited)
Thanks a lot! I found it. Now the strangest thing is that I have a newer brain (65711387625). If I read the documentation right it should fit, but it's not. The car-connector has 1 'square' too many preventing it to be plugged. I read Exchangeable retrospectively as 'can replace older parts'
So there are two possibilities.
1. I misunderstand the OEM documentation.
2. The documentation is wrong.
What is it?
1012896
BMW CCA 1405
1997 BMW Z3 1.9
I don't know.
Is it possible your connector will fit the part number 65718369063 that you highlighted in yellow?
When I put that number into ECST, it changes to the next number below it, and no photo:
Warning - Thin Air
It looks like the link below has good photos of the module connectors. The link is for the part number in your post #3, but you can put in the part number for your other options to see if any of the connectors look like they will fit.
Discussion Starter #6
I don't know.
No, it does not fit. My connector cannot be plugged into part 65718369063. I guess my last q is if it SHOULD according the OEM documentation. (Or the ECST. )
Discussion Starter #7
Judging by photos my connector fits only ***625 and older modules.
1 - 7 of 7 Posts
