Depending on the year some are located behind the rear bumper. I believe 2010 models are located behind the rear bumper.The ANNTENA is under car located also just under the driver seat. The RDS is in truck right side under the tray.
mine is 2010 and i just had to install both of them. i got tmps malfunction so purchase both modules and had to find them.Depending on the year some are located behind the rear bumper. I believe 2010 models are located behind the rear bumper.
Did you change both the RDC control module and the antenna at the same time? What systems had to be reset when you reconnected the battery?I changeD the RDC on mine and there was no reprogramming. I did disconnect the battery when I replaced.
no programming needed. i purchased new from dealerHey there,
Just saw your post on replacing the TPMS RDS and Antenna....I just got the TPMS Malfunction Error and went to Discount tire and had them check each wheel etc. All wheels show good battery life and all are operational. So it has to be the other 2 modules (same ones you replaced) that are causing the issue. Did you have to reprogram anything when doing the install your self?
User7007
