Actually, the reason NOT to shift in the turn you describe is not because you want to keep your hands on teh wheel (although that is a good reason) but mostly because, if youa re actually at or near your tires' adhesion limits, the disturbance in power application caused by the shift could be enough to unsettle the rear and cause the tail to come out. At high enough speeds, you lose control and wreck.rost12 said:
Smoothness is key. Anything that upsets that smoothness is bad. Unsettling the car in max adhesion situations can be VERY VERY BAD.
