1 - 6 of 6 Posts
Hi,
Any recommendations on a shop in Los Angeles area to perform automatic transmission fluid change. I have a 2012 328i coupe with just under 100,000 miles. I now realize I should have done this some time ago. But better late than never.
Thanks,
Jedi85
My independent BMW mechanic does that. I buy the service kit and he does the job...
Ideally you would want to find place which has equipment to replace (they open the fluid flow to radiator and dump old while pump pumps fresh one to the system) 100% of fluid but it won't be easy or cheap..
Second best is to replace whatever you can...
BCI Motorworks Bimmer Clinic in Reseda, Cal. I've heard they're a good BMW shop. I personally never been there, I don't trust any shop! That's just me, I do all the work on my BMWs... You can look them up and see what you think.
Bavarian auto house German car specialist in Anaheim they do a good job
If you pay cash you save 10% on cost
Call Steve
I used the dealer for mine. TBH, this is something that's done every (somewhere between) 60K and 100K miles. For me, it will take 5 to 7 years to accumulate that mileage. So, with the infrequency of this maintenance item, I'm OK to let the dealer do it.
Something more frequent like an oil change ? Sure, indy is fine.
1 - 6 of 6 Posts
