Any good advice on where to place a floor jack onder an E46 to safely jack the car up and get it on jackstands? I've really struggled with this, and have used a point that I am unwilling to use again -- the U-shaped reinforcement rails that run front to back along either side about 12-18" from centerline. I ended up deforming the rails very slightly :eeps: (indented, not bent), and while I don't think If done any serious damage, I don't want to jack from these points again.
BMW will only say that the four factory jack points (two on each side -- where the factory tire jack goes) are the ONLY safe places to lift the car. Problem is, this is where I have to put the jackstands!
So, anyone...help! FYI, I'm doing this work on a 330cic.
Dave
