1 - 20 of 21 Posts
Wow Autozone sells fly wheels for our cars!:yikes:
Discussion Starter · #11 ·
I believe Sachs bought Luk.....so no choice there. One thing that has been mentioned, is that many of the cheaper Ebay and other non OEM distributors of Luk/Sachs use older versions that don't have the newest revisions.
OK, So I saw some LUK/Sachs on Ebay and prices are decent. But what do you mean the newest revision? Do you mean their Luk/Sachs are antiquated? Do I have to get the kit from a known good distributor in order to get the latest revision?
Discussion Starter · #12 ·
It's hard to get the material out of the crevices. If it hasn't been destroyed you can just clean it up with scotchbrite.
Jared
Hey Jared,
What about the thickness? Can I measure the thickness of the dual mass flywheel to determine if it needs a new one or what not?
Thank you for all your help.
I mean resurfaced by the machine shop, not by scotchbrite.
I know. That's what I meant. Resurfaced by a machine shop may leave some materials in the hidden crevices of the DMF. It's not recommended. So, to get around it I'd just take the glazing off with scotchbrite. That will work find if it isn't destroyed by heat.
Jared
Check UUC's posts on bimmerforums. They recommend replacing the flywheel after 80k and using a reputable seller of LUK etc. There are constant revisions going on with the clutch and flywheel over the years. The older versions are still sold.....but by second tier resellers. If you want the best and newest.....you need to pay the piper (all info from the UUC posts by Rob Levinson).
Rob recommends always pulling the flywheel after 80k. In his opinion, not worth taking the chance of having to do it all over again to save a few hundred.
I replaced my clutch at 80K miles and didn't replace the flywheel. My mechanic inspected the flywheel after it was removed and he said it's still very good condition. I am at 120K miles and the car drives great but YMMV.
The dual-mass flywheel should last at least another 100k miles. If the clutch is replaced in time without damage to the flywheel then I would invest the money in an upgraded clutch in order to get more miles for the same labor cost. Thus, save the $400-$900 from the new flywheel you wanted and get a clutch with higher temperature tolerances than the OEM clutch. UUC has really nice items. Your other option is to get an aluminum flywheel with a carbon clutch but you are up there on pricing ($1,400 to $2,000 on parts alone) Check other reputable brands if you don***8217;t like UCC, LUK or Sachs. I have 180k on my E39 with one clutch job (LUK OEM) and the same factory installed flywheel (resurfaced when the clutch was replaced.) Let us know how it goes.
You cannot resurface a dual mass flywheel. There is no two ways about it. If there are hotspots or scoring it must be replaced.
Purple Label
I want to stick with OEM. Should I go with Luk or Sachs? And should I replace my fly wheel? 97-528 with 152K miles.
only 152K I just replaced mine @ 173.5K AND, AND, I learned how to drive on that clutch....
Exactly....I just had my clutch replaced and I luckly did not have to do the flywheel.
Also, go OEM BMW on the parts. Mine were abot $250 from the dealer (but I get a good discount).
1 - 20 of 21 Posts
