Fronts at 12.6K and rear at 23.5K
Based on the pic in your sig, I would say that you are probably hard on brakes and therefore, replacing the fronts for slight warpage makes perfect sense.nate328Ci said:My pad light went on at 12.6K miles and the rotors were replaced due to light warping. The rear rotors were replaced along with the pads at 23.5K because they were too thin. At 28K miles, I had new front pads put on, but the rotors are still true...
Because of the heat and moisture that rotors are subjected to, any part of the rotor that is not touched by the brake pad will rust. This will give the impression that the pads have "worn" the surface of the rotor down. However, rotors are cast steel and will NOT get worn down by brake pads. The only way a rotor can get worn down is through machining them to make them true or when resurfacing them (usually done when installing new pads to give the pads a clean surface to bite into).geomax said:
While washing my wheels some time ago, I happened to look thru the spokes and saw that the rotor had the outline of the brake pad stamped into it. Driving the car doesn't seem to wear it off...it seems permenant...it's odd...what could cause that??
What I meant was that the pad outline, if it were rust, should get scraped off. But it doesn't go away. It's as if it's engraved in the surface of the rotor. So my question was, how did the outline get "etched" in??virtualrain said:
I am definitely starting to believe this - and will likely eat my earlier words as a resultDrBimmer said:BMW rotors are designed to wear out along with the pads. Those of you that are used to just slapping on new pads and turning the rotors are out of luck here....
I'm sorry. I'm not sure. Perhaps some other folks can shed some further light on the whole rotor/pad design since it seems very unconventional to me.geomax said:
Doesn't BMW use non-metallic carbon pads? :dunno:Fronts at 12.6K and rear at 23.5K
