yes, clams are up and removed. upper came off without issue, it's just the lower connection to the radiator that is the stopping point now.You've removed the hose clamp and tried twisting the hose? Often times they get stuck on there over many years and need a little coaxing. Or cut a slit perpendicular to the mounting location, then twist it around some.
I'd work the retaining clip to make sure it's all the way up and then try to wiggle/pull the hose free.yes, clams are up and removed. upper came off without issue, it's just the lower connection to the radiator that is the stopping point now.
Draining the radiator first should help with this. There's a blue drain plug on the bottom of the radiator.... Plan for a coolant spray shower if you are underneath when it finally pops off...
already drained.Draining the radiator first should help with this. There's a blue drain plug on the bottom of the radiator.
Also had this happen once. Stop whining and get it done. Giving up....what's that?already drained.
I'm giving up. THanks guys. Just going to leave the old lower hose on and pay someone a few months from now to do a proper flush and to replace that hose.
I think you'll damage the plastic radiator neck and be buying a new radiator too.I will be doing this job in the near future and I'm thinking of getting my Dremel out and cutting the plastic coupler of the lower hose. What do you guys think?
Yes, I must be careful to not cut too deep. I'll try wingspan's lever method first and see how frustrated I get.I think you'll damage the plastic radiator neck and be buying a new radiator too.
It's weird, some come right off (my car) some fight like crazy to come off (dj330ci's car).Yes, I must be careful to not cut too deep. I'll try wingspan's lever method first and see how frustrated I get.![]()
Spray it down with PB Blaster/Liquid Wrench to break the surface tension then pull straight back HARD. Do not twist it, you will shear the lug off of the rad outlet.Been dorking with this thing for 2 hours and can't get the damn hose off the radiator. Any suggestion?![]()
That is true, unfortunately, at least in my case, there was *just* enough fluid left in the rad to spray my face with coolant when the thing finally popped off...Draining the radiator first should help with this. There's a blue drain plug on the bottom of the radiator.
HA HA. See 8:01 on the vid.......That is true, unfortunately, at least in my case, there was *just* enough fluid left in the rad to spray my face with coolant when the thing finally popped off...![]()
