1 - 10 of 10 Posts
Hello everyone this is my first post but I'm sure not my last. I just wanted anyone's opinion and/or experience as to whether running 265/30/19 tires on 19x9.5 rear wheels will present any rubbing issues? The fronts are 19x8.5 with 245/35/19 tires on an '05 330ci cabrio if that matters. Any feedback, recommendations or advice would be greatly appreciated, THX!!
Keeping it surreal
You`re probably gonna have some rubbing under certain circumstances....a lot of people don`t realize there`s a *big* difference in tire clearance at static (i.e., parked) ride height, and at full compression....bumps, railroad tracks, extra passengers all may contribute to rubbing. What`s the offset on those rear wheels ?
Discussion Starter #3
Offset is 35 upfront and 40 rear. Is there a different tire size you would recommend for optimum performance and appearance that won't cause rubbing?? Thx for your input!
Keeping it surreal
255s would be probably OK with the 40mm offset, you would`nt want to go any narrower with a 9.5-inch wide wheel. The shape of the tire`s shoulder also makes a difference...."square-shouldered" designs usually give a little less clearance than round ones....
Discussion Starter #5
Good info thx. Seeing as how we have similar cars, would you know if there would be a significant gap in the wheel well that you would recommend a slight drop for appearances sake?
Keeping it surreal
Most likely you will not rub. My friend runs 19's with a 65 on the back on his ZHP. It looks WIDE back there and he swears that he never had it rub.
Yeah, but it all depends on the wheel`s offset....as the rim gets wider, more offset is needed to keep everything centered....the OP`s rears are 40mm, not quite enough for a 265 to fit without rubbing (I *think*). IMHO, he would need 50mm out back for 265s....
Is it Trackday yet?
Agreed. Every time this question of 9.5" wide rear wheels comes up, I chime in with my story of 8.5" wheel with +42mm offset and 255/35-18 tires rubbing UP inside the fender well. Funny how that doesn't show up on the search though.
Keeping it surreal
Try it at stock height first. While a bit of drop always *looks* nice, it also increases camber, leading to faster tire wear....most people don`t want to have to replace those expensive tires every 12,000 or so miles just to look cool....
Discussion Starter #10
Thx for all the help guys, y'all have been extremely helpful and i'll have to post some pictures of the ride and show you the results soon.
1 - 10 of 10 Posts
