I can hear clicking ! It's not the battery I took that to advance they tested it was good. I'm watching YouTube videos seeing if people had the same issues.If you can hear the fuel pump prime, my guess is bad starter or start/stop button.
If ignition won't switch, its most likely the button. If it does, then possibly starter.
If the starter does engage and just keeps cranking, assuming you have fuel pressure and spark, could be bad crank position sensor.
Have lights. Car in park. All electronics work.It might be helpful if you gave us more information. Does the engine crank? Do you have lights? Is it in park (or neutral) when you tried to start? Do any of the electronics work?
