1 - 2 of 2 Posts
kccomatt
I was wondering if anyone knows whether or not these wheels would fit my 2001 BMW Z3 2.5i Roadster:
Front; 17x8 ET40
Rear; 17x9.5 ET15
Center Hub Size; 72.56mm (says they come with hub-centric rings)
They are SSR Type-C
I'm lowered on BC coilovers and would not mind having to run spacers/modest front camber. Trying to get a flush fitment.
Any feedback would be much appreciated, thank you.:D
KCCOMATT, I'm running 16in x 7 1/2 in wide rims all around and have to run spacers to clear my coil overs in the front. Mine is lowered slightly, but not much as I'm starting to get flush/outside the front fenders. There is plenty of room in the rear, but I spaced the rear out to match the front. If you're going to stuff 17s under the front, you might want to do some serious playing around with a dummy rim and mounted tire. I don't know how any others are fitted with their shoes, but mine is about as far out in the front that I want them without any interference. Good luck.
1 - 2 of 2 Posts
