Decent looking wheels....the 19x8.5 with a bolt circle of 120x5 and 35mm offset *should* fit ok, but you might experience some rubbing when hitting a bump while the wheels are turned.... in which case, you may need to have a body shop roll the fender edges for clearance. Many here are of the opinion that 17s are probably the best all-around choice for the E-46....there`s a lot of merit to that opinion,(check the archives), but if you`re after the "big-wheel look", then by all means go for it.
Regards,
Bob
