I'm expecting delivery of my 2013 AW 335i Sport come the end of this month.
The seller stated these would fit my car perfectly, but I'm hesitant to believe him. Any ideas? Also, tire size recommendations? Thank you for any input.
It's gonna be close, but more importantly the centerbore is off, these weren't made for your car just FYI. Might want to look at something else if unless you are comfortable running a hub ring.
We've had good success with some of these options:
If you have any suspension issues BMW will probably use the rolled fenders as evidence of not using the car as intended and will deny any suspension related warranty claims. This could also carry over to other claims such as steering angle sensor, wheel speed sensor, ABS sensors, a whole host of possibilities.
The H&R Sport Springs is a perfect drop, its not to low, but its enough to clean up the wheel gap. Add a nice set of 20" wheels and you have yourself a perfect stance!
I had some 17" wheels that required the use of hub rings to fit the hubs on my 2000 A4. I never got proper balance with those wheels, I would get a little bit of vibration above 65 mph or so. When I would switch back to the stock wheels (which I put winter rubber on) I never had the issues, so it was either the wheels or the hub rings but I always suspected the hub rings.
If I get winter wheels for my F30 I will get ones that fit the car properly and do not require hub rings.
Thanks for the input everyone. These wheels are hub centric, so fitment should not be an issue, according to the distributor.
My car is at the dock now. Should be at the dealer in about a week.
I will post pics once I have everything installed. I'll let you know how the ride is as well. Hope I don't need anything additional...*fingers crossed*
