1 - 2 of 2 Posts
My driver window button is busted. It won't open or close. The button is just flimsy. No resistance. Is the there a website I can goto that could tell me step by step what to do? I want to know how to remove the window console without damaging the wood trim.
Thank you very much, Alex
Ubergeek
Removing the shifter console is a breeze... with a manual, just pull the edges of the shift boot in toward the shifter to get it off, with an auto, just use some sharp plastic piece to pry the area around the shifter off - it's very easy to remove without damaging anything. Once you've done that, only two screws hold it in.
You can find the p/n for the button @ www.realoem.com/bmw and order a new one from several sources listed at the bottom of the wiki
1 - 2 of 2 Posts
