1 - 12 of 12 Posts
I've just received a new regulator and a couple of these clips have been included:
1028272
Unfortunately, the instructions are not very clear as to where they go, and I can't find any videos or pictures that show them in-situ - can anybody enlighten me?
Many thanks,
M.
these clips are used to hold/attache the regulator arm to the window. I don't think they come with the regulator purchase---at least not the regulator I bought here in the U.S. You might not need them since you already should have them.
Discussion Starter · #4 ·
The instructions advised me to replace them - I will if I can :)
They attach the regulator to the bottom of the window. If you Google BMW e46 window regulator replacement you will find numerous videos. The 50sKid has a very good video on this and just about anything you might need to do to an e46. He is very thorough and clear on the process.
Yes youtube videos are good for learning what to do before you accidentally broke something. Doesn't hurt to have spare plastic parts, but you might not need them.
Discussion Starter · #7 ·
I can't find any videos where the clips are exposed or replaced - looks like everybody goes the easy way and reuses the old ones!
Might be that those pieces aren't shown in videos exactly, but they are right there, in the lower end of the window. Might be that original ones are black?
You will see them once you pull the door panel off and start the replacement process.
Sent from my SM-N960U using Tapatalk
They are literally attached to the bottom of the glass and are visible only in a certain positioning of the window.
Once you get this it will become very clear. It is a necessary ability to know if you own an e46, since these regulators tend to fail frequently at this age of the vehicle.
My 330i regulator failed last year so I replaced that (front passenger side). I reused the old clips because they were still in good condition. I think I saved the new ones ... Somewhere.
Discussion Starter · #12 ·
I've just finished the job - winodws is working again - and I saw the clips at the bottom of the glass.
I reused the old ones, though - I only do two or three thousand miles a year in the bloody thing!
1 - 12 of 12 Posts
