1 - 4 of 4 Posts
· Registered
2001 Z3 2.5i, Trying to troubleshoot my windshield wipers. They keep blowing fuses. Motor was working fine then all of sudden it started blowing fuses. Now every time I try and switch them on the 15A fuse blows.
· BMW CCA 1405
1997 BMW Z3 1.9
· Registered
Discussion Starter · #3 ·
UPDATE: I have been doing some troubleshooting. Fuse 44 blows as soon as I turn the ignition to position one. I have disconnected the ditch in the steering column, still blows. I have disconnected the washer pump, still blows. I have changed the relay, still blows. Only thing left is the wiper motor. I have read that there is a micro switch inside the motor that seems to go bad. Anyone have any experience with this? Is there a wiper control module and if so, where is it located?
· BMW CCA 1405
1997 BMW Z3 1.9
... wiper motor... keep blowing fuses. Motor was working fine then all of sudden it started blowing fuses. I have read that there is a micro switch inside the motor that seems to go bad... Is there a wiper control module and if so, where is it located?
Wiper motor switch mentioned in #2 in here:
https://www.ecstuning.com/b-genuine-bmw-parts/fog-light-cover-right/51118398012/
Control unit for wiper washer in eBay:
https://www.ebay.com/itm/BMW-Genuin...228213&hash=item542c1cd053:g:20MAAOSwxcRW8jkr
And from ECST:
https://www.ecstuning.com/b-genuine-bmw-parts/wiper-washer-control-module/61358366381/
Located behind glovebox, but is called a relay in the attached instructions. I wonder if either the switch or the module can short the fuses.
1 - 4 of 4 Posts
