1 - 3 of 3 Posts
My wipers stopped working and after a little research I thought replacing the two violet wiper relays in the e box would be the best place to start. Did not cure my problem. So. My next step is to get to the motor and see if it's getting power. P.s. I checked the fuses. Once I test and see if the motor is getting power when I hit the switch I'll know if it's the switch or the motor. That being said I need some help on getting to the motor and how to actually go about testing it.
The wiper relay is tan in the e box-when my wipers went out i cleaned the contacts and reinstalled the relay and they worked again
Discussion Starter #3
In 97 they used two violet ones instead of the one tan one. I replaced them both. Still nothing.
1 - 3 of 3 Posts
