1 - 10 of 10 Posts
Hi everyone I've tried to flash unit 61 cbx-ecall and got this error
any help
Sent from my SM-N920C using Tapatalk
Are you using a charger? 70amp or better? Programming F or E series car?
can you show your winkfp setting page?
can you flash other modules? does inpa work correctly?
how did you choose the ZUSB
whats the error code?(can't see it on your picture, should be on top of the window)
Discussion Starter #9
Yes I've flahed other modules and inpa works correctly and the errocode is 7057
Ballin' out of control.
That's error is due to a timeout on the MOST bus. Check your remote.ini settings.
1 - 10 of 10 Posts
