1 - 20 of 22 Posts
OK, so I use our trusty install package from here with all the BMW TOOLS. INPA works fine. WINKFP reads my modules firmware level, but will not write any new updates. Error 209. UIF error. So I turned off the UIF write thinking the max writes were reached. Closed it down, reopened, and still getting error 209-UIF....WTH? Why if the UIF writes are off? Either I am slow (probable) or I am missing that something. Any ideas?
2005 545i, Sport......
Is your obd cable set correctly in Device Manager Com1 and Latency 1 ?
Post your Winkfp Configuration Picture
Check
Force program programming in comfort mode
UIF write after date
UIF Write after program
UIF write in ComfortMode
And Show Programming Voltage not needed in your case
Than youbare doing something wrong, you need to reinstall standardtools or its your spdaten or cable, which module you are trying to update?
Discussion Starter #9
I have tried about 5 modules...no results.
Cable says its K+DCAN, USB INTERFACE
INPA COMPATABLE
What modules are you trying to update and why do they need programming?
As mentioned here is a configuration issue as the program works generally well.
Discussion Starter #11
The car is a 2005. The lastest daten files that I got from Shawn sjhowed about 8 modules needed up dates. I will run thru it again after lunch and let you know. I just got INST installed, also. Give you an update later.
Discussion Starter #12
Don't matter what module I try...it fails. Error 209 UIF error, even with the options unchecked. Also, I don't see and voltage showing in the upper right corner. Says VOLTAGE 0.0
this is a compatibility/ installation issue most likely.
USB cable can not display voltage, only ICOM.
do not attempt to flash CCC navigation with this cable as it will fail most likely.
to flash CCC ICOM is needed with MOST adapter.
All other modules are possible with a K-Dcan cable. The cable from bimmergeeks works great.
Get the cable from Bimmergeeks and software from them
1 - 20 of 22 Posts
