Better idea buy a Jeep to drive in the winter![]()
The only thing that i do not like about the 640M or 641M wheels is that they are staggered. The tires are the same size. I don't understand why they also didn't make the wheels the same size to allow rotation.So I'm going with the offering that BMW AG has at my local dealership. €2050 (VAT exempt) with 640M rims(TPMS) and tires. Less hassle and not too far off from the cheapest wheel/tire package @Tirerack. Plus they are OEM. That was something that totally annoyed me with my previous Binmer. Rims with some other logo on them and having to buy adapter rings for them every time I had a rotation or seasonal changeover.
I typed this up on my Smartphone using Tapatalk![]()
Weird, because when I asked if any rims accepted OEM BMW center caps I was told "no"I think the rim I got accepts a standard BMW center hub. That is what the Tirerack sales man told me, and I found them to be pretty accurate with that kind of info. I agree I'd rather have the correct logo. I'll give it a try when I swap to the winter shoes.
Mike
Many have. But really, you're much much better off in a big 4x4, inclement weather. Aren't you?Has anyone picked up a winter wheel pack (rims + tires) from tirerack for the M4? Would love any recommendations/pics if you have.
I'd like to understand the rationale on this as well. Handling?The only thing that i do not like about the 640M or 641M wheels is that they are staggered. The tires are the same size. I don't understand why they also didn't make the wheels the same size to allow rotation.
Keep in mind the offset is tied to the wheel width. Meaning if the wheel width changes then the offset will change too in order to have the same position. The 18 inch wheels that tire rack recommends for winters are basically all 8' wide.I'd like to understand the rationale on this as well. Handling?
Also, on every TireRack set I've looked into the offsets are not exact to OEM. Some closer than others, but none spot on for all four corners.
Again, curious about how this does, or doesn't effect the handling characteristics of the car?
I'm interested in the group ***** please keep me posted. Currently contemplating OEM winter set vs TireRack set. And while I understand the benefits of 18s for winter use, I really don't like how they look on the M4.Keep in mind the offset is tied to the wheel width. Meaning if the wheel width changes then the offset will change too in order to have the same position. The 18 inch wheels that tire rack recommends for winters are basically all 8' wide.
BTW, we are trying to set up a group buy for winter sets (wheels and tires). We are in the process of calling places now and getting quotes. If anyone is interested, come back to this page and hopefully should have more info by the end of the week
Also, the stagger seems to vary even in the various 8" wheel options offered by TR.Keep in mind the offset is tied to the wheel width. Meaning if the wheel width changes then the offset will change too in order to have the same position. The 18 inch wheels that tire rack recommends for winters are basically all 8' wide.
Hey Visi,Keep in mind the offset is tied to the wheel width. Meaning if the wheel width changes then the offset will change too in order to have the same position. The 18 inch wheels that tire rack recommends for winters are basically all 8' wide.
I have a 2016 M3, competition package (regular brakes). Would you mind letting me know the cost? Do you think Pirelli Winter SottoZero or Blizzaks are better?It's actually a bit tough to find the right set of winter spec wheel & tires that clear the larger brakes on these cars. We've found that 19" opens up a lot more possibilities and options. A fairly common spec would be the 19x9.5 ET22 with a 255/35/19 all around. Shown below is a set of the VMR V710 in Gunmetal in the exact specs mentioned. We wrapped them on a set of Pirelli Winter SottoZero Serie II tires that were shipped out to another M4 owner & customer of ours.
