1 - 18 of 18 Posts
Discussion Starter · #9 ·
1997 528i
Is the build date before/pre 03/98?
This might help.
And according to that mine has 2 different relays for the wipers 🙄 5 and 6. I was told the relay was a bmw dealer only part but the one I got from the dealership looks and is laid out just like a standard 5 pin relay? So why's it a dealer only part 🤔
Discussion Starter · #14 ·
Were your wipers working and then stopped while you were driving or you tried using the wipers and they would not turn on.
They were working fine. Then one day I went to turn them on and nothing.I was told by the previous owner that he had had issues with them but got them working. I guess if I was smarter I would have asked what he had to do. But when I realized the bolts on the dme were frozen I know it had not been opened before, and when I opened it I confirmed it bc all relays were og. So I'm figuring that's the issue but on my car there's two of them and idk if there the same thing 😐
In some cases I have read that giving the wiper motor a tap with a hammer gets it going, it’s worth a try but you need to remove some bits to get to it, that’s the drawback. Sometimes it’s the wiper linkage that’s binding, you gotta look at everything. A coworkers 2008 X5 wipers were not working a few years back, I found that the linkage was loose, adjusted it, tightened everything, and they still work to this day.
Discussion Starter · #16 ·
So here is a plot twist for you I go to get in my car this morning because I need to use it to go to work and at rain last night for shits and giggles I turned on my windshield wipers my windshield wipers and they randomly came on after not working for months and the only thing I can think of I can think of is that when I open my DME Box finally I checked and pushed down on all of the relays but never tested to see if my windshield wipers worked so that might be the problem A simple loose relay hopefully
where da clutch at ?
2020 BMW 230i
with cars as they get older, loose connections either fuses or relays
the first thing I ever do on a car with wierd electrical is push all the fuses and relays in
1 - 18 of 18 Posts
