Hi All,
I read the other posts regarding the Wiper Relay and Motor but there is a slight difference with whatI am experiencing.
When I put the key in and press start(doesn't matter if I start the engine or not). I can turn the wipers on and they'll stop in the middle of the windshield after about 4 or 5 times back and forth. I can turn them on one more time and they'll move again, 4 or 5 times.
After the second time, I cannot turn them on at all. I tried rotating the timing dial, using the auto function but nothing, I literally have to remove the key, put it back in and turn the car on again.
So far, I have replaced the Relay - Same issue.
Replaced the Wiper assembly with new motor - Same issue.
I am leaning towards the control switch or the Rain Sensor being bad. Obviously the rain sensor would be easier.
Thank you in advance for your help.
BMW Adrenaline
2011 BMW 328i
