1 - 8 of 8 Posts
I bought a 2003 bmw e39 530i a couple weeks ago and I got a P0304 code. They told me that the sensors were bad so I ordered all of the sensor. I replaced the two crank shaft sensors but I can***8217;t seem to get the Variable Timing Solenoid Dorman off to replace the cam shaft sensor. Some idiot rounded the bolt so I can***8217;t get a wrench over it without it slipping off. I***8217;ve tried everything. Wrench, adjustable wrench, and even vice grips locked on it impossible tight. Nothing will turn this. I***8217;m going the right way because I***8217;ve watched every video known to man on YouTube about this. Mine just won***8217;t come off and I have no idea what to do. It***8217;s like completely rounded. Please give your suggestions.
Much appreciated.
- Get a new (or used) VANOS solenoid from local junk yard or ebay for $25-$30. Use realoem.com to find the proper PN.
- Then be prepared to destroy the existing VANOS solenoid by using a Pipe Wrench on the body of the VANOS solenoid. May want to add a piece of rubber so it bites better.
- Re tool: I have the Fan Clutch tool 32-mm and 36-mm combo type.
Discussion Starter #3
The body of the Vanos is spinning. I can spin it with my fingers. I didn***8217;t think it was normal. Is it normal?
Discussion Starter #7
I***8217;ve used the 32mm wrench from my tool set. It just refuses to back out! I***8217;m going to go to the store and get a bar to slip over it to give me more leverage but this is ridiculous. It shouldn***8217;t be on this hard. And is my vanos solenoid trash now? Also what does it do for the car?
The 3rd photo showed you turned the body CW.
To remove this, turn the 32-mm DOWNWARD, which is CCW.
This device activates the piston inside the VANOS.
1 - 8 of 8 Posts
