1 - 6 of 6 Posts
-Take off brake caliper
-Take off brake rotor
-Remove center cap hiding the bearing nut
-Remove nut holding bearing to knuckle - Need a larger breaker bar
-Remove bearing
-Replace with new bearing
-Replace with new bearing nut
-Replace with new cap
Bearing nut is 200lb-ft torque
Cross reference the E46 procedure. Not very difficult if you can change your own brakes. Hard part is borrowing the large socket and torque wrench capable of 200lb-ft
Discussion Starter · #4 ·
Thanks for the info.
From what I can find so far, it is suggested to use a slide hammer to remove the hub, leaving the axle in place.
Then remove the snap ring and use some sort of 3 jaw puller to remove the bearing.
As i have never played with BMW's I can only guess all the bearing will need to be pressed either back in and or back on the hub during reassembly?
Some DIY's use all these fancy pullers blah blah blah. My last front bearing just slid off the knuckle using my hand.
The rear bearings is a headache. Those require a slide hammer. Fronts normally just slide right off.
1 - 6 of 6 Posts
