1 - 6 of 6 Posts
4e81 82 84 92 98 4ea2 4ec8
You posted in the wrong section but a moderator can help you with that to move it. What transmission work did you have done? Are you driving it but getting these codes? Symptoms? Symptoms before the recent work? Why not take it back to where you had the work done?
Reading through your other post maybe you are low on fluid?
Discussion Starter #4
I am driving this car with no issues when it's cold. When it gets heated up like more than 90degrees and more the issue arises... Mainly slow driving which involves frequent gear shifting and reverse... During reverse gear it goes to neutral after moving a bit
Discussion Starter #5
Not low on fluid. I suspect the solenoids got to do with the issue as many people suggest not to change transmission oil if it's over 200000kms
Resident Curmudgeon
lol
Yeah, just replace the tranny.....
Drop the pan, clean solenoids, replace seals, refill. Duh
1 - 6 of 6 Posts
