1 - 3 of 3 Posts
· Registered
I have 2 keys now not working on my 04 X5. I have sent one to Scott, who said it worked and returned it. Since the interior dome light works, he also said that it wasnt a GM3 problem. Fuses are OK.
I decided to open up the rear inside upper hatch panel and uncover the FVZ antenna module. I tested the 3 contacts with a light tester, and found NO positive voltage to light it up. However, I have no idea where that wiring is coming from. (Yup, I have the Bentley manual, but try to figure that one out!) Not sure if it's a fuse other than #7, Radio, which works.
I also see that there is another module (antenna amplifier) in the back rear pillar, but havent pulled that yet.
My car has had a roof leak as a result of a panoramic roof that has not closed fully. My sound amplifier has been fried. I suspect that there's corrosion in that connection somewhere. Getting frustrated with no keyless entry!
Anyone have a similar problem?
· Registered
Have the same problems as you however I had AM working and not FM. Replaced the amplifier in the trunk lid and the module over the left rear tire without any luck. I do know the smd caps in the old modules had degraded over time but never tested them with new caps. There's a way to reprogram your keys floating around in every forum but that hasn't helped me.
Your Amplifier needs to be replaced. If you open it up, you'll see corrosion everywhere inside. Not repairable.
Let me know if your driver side door lock actuator starts to go out. I just replaced mine and still can't unlock it using the central lock. Key fob only helps to unlock the door and start the car.
· Registered
To clarify, I replaced the antenna amplifier, which may have had degraded capacitors. I got a reading of 89uf and 70uf on the 100uf 25v caps.
The audio amplifier under the tire is what develops corrosion.
1 - 3 of 3 Posts
