I have pretty much looked over all the BMW forums for info on "Missing BMW Scanner v1.4 Drivers" ***8230;.. and not come up with a solution in my case.
I have installed Windows XP (64) on my MacBook Pro, running Parallels 13), and then installed the "BMW Scanner v140 Install.exc", and had no problems with the initial software install.
However, when opening the "BMW Scanner" desktop alias (shortcut), the pop-up window shows that "Device drivers are not installed". Looking at the "C" drive>BMWScan140 Folder> it shows the "scanner app" along with the "drivers" folder ***8230;.. here's where I am lost for solutions (see attached screen grabs).
Not being a real "Windows expert or knowing my way around the PC/Win environment (know practically everything about Mac/Apple, not so much when it comes to PC/Windows), I'm not able to get the "drivers" to engage with the actual "BMW Scanner" hardware unit (even though the BMW Scanner hardware shows as "connected" in the upper Windows XP menu bar) (see attached screen grabs).
If you look over the attached screen grabs, and see what I have available for drivers ***8230;.
1. Does it look like what I need is on the MacBook (just not installed properly or in the right place, right settings?
2. Or is there "driver software" missing that I should have available to properly install BMW Scanner 1.4?
Any assistance/suggestions will be appreciated, and I'm sure come in handy for others to know in any similar future install situation they may encounter too. Thanks!
:bow:
What I'm Using:
***8226; '97 528i
***8226; BMW Scanner OBD Unit w/USB Cable
***8226; BMW "Round 20 Pin" BMW Engine OBD Connector Cable Adapter
***8226; 2015 MacBook Pro running Win XP Pro (64) on Parallels 13
:bow:
What I'm Using:
***8226; '97 528i
