Good luck getting the 6.5s to fit in the front door. I think its possible, but I guarantee it will be a LOT of work. I got specific adapter rings for the car from the UK, and test-fitted an old set of Boston Pro 5.somethings, and they dropped right in (I'm putting Focal Polykevlars in, though).
I'd keep the separates back there, and either find a nice place on the deck for the tweeters or put em in the stock midrange location and set the component's crossover to as far down on tweeter output as it will go (-6db?).
As for the wiring, if you don't wanna cut any wires, you're gonna have to build up some sort of custom wiring harness to plug into the amp plug. I'm working on piecing one together out of other harnesses for other cars that I have lying around the house.
Good luck!
Good luck!
