I have a blown headgasket on my 97 Z3 1.9 (water in the cylinders when you pull the plugs).
As I see it, I have two options:
A.) Pull the head and have it reconditioned and bolt the motor back together.
B.) Pull the motor and rebuild it.
I'm inclined to pull the motor, but the question is... "what is the best method for removing the engine?"
is it better to pull the motor up and out as is the way I've always done it or is it easier to just lower the front end out of the car with the motor attached?
What's involved in dropping the carrier to get the motor out?
any information would be appreciated.
thanks
RuprectGern
thanks
RuprectGern
