After being gone for a month I startede up my wifes 2001 Z3 Coupe and the DSC Light came on after a couple of seconds. Stopped the car and turned it off. Started again and the same thing. Now it is on immeditaly and stays on. No BRAKE light though.
Thinking I just needed the codes read I took it to my indie who has the Auto Engenuity software. This could not see the DSC controller but the Steering Subsystem showed the Steering Angle Sensor reading -1024. The Weel speed sensors were 0 and 0.3 but did not change when a wheel was turned.
As far as I can tell ABS is still working (if I slam on the brakes on dirt they pulse and the car stops straight). I think this tells me that the control module is OK as both DSC and ABS are in the same module.
So I suspect the Steering Angle Sensor and my questions to the experts are these:
1. How can I confirm this diagnosis
2. Is this an easy DIY and is there one I can follow.
3. If I do DIY it seems that the new one will need to be calibrated; can only the dealer do this? If they are going to rape me for that should I just have them do the whole thing?
Any comments are apprectiated.
