measure the oposite wheel
i have never seen one adjustable. are yours ?
it should NOT rub
According to the Bentley Z3 manual (you do have one, don't you?), there is no spec or adjustment for the wheel speed sensor gap. It appears that if a pulse wheel is damaged (which would seem to be the problem if the pulse wheel only contacts the sensor during part of the rotation), you replace the part that includes the pulse wheel (front wheel hub or rear outer CV joint).
Manuals? na mate, that's for women.
That's what you got from my post? Do you think the design is for the sensor to contact the pulse wheel for part of the rotation? Does that seem right? No, the speed sensor should NOT contact the pulse wheel. It should at a close tolerance so that the sensor can sense the pulse wheel passing by it.So am I to understand from your post that the sensor IS supposed to be in contact with the hub rim?
And for people who have to ask elementary questions about their cars.
Your wording would suggest it needs to contact on full rotation.According to the Bentley Z3 manual (you do have one, don't you?), there is no spec or adjustment for the wheel speed sensor gap. It appears that if a pulse wheel is damaged (which would seem to be the problem if the pulse wheel only contacts the sensor during part of the rotation), you replace the part that includes the pulse wheel (front wheel hub or rear outer CV joint).
To be fair, that's what you intimated in your previous post
Two parts, with no rollers or other moving components between them, and no lubrication between them, contacting each other during the full rotation where one moves and the other does not move . . . what might the result be?Your wording would suggest it needs to contact on full rotation.
Yeah, common sense would seem to suggest that.But yeah, common sense would suggest there should be no contact - just hovering over the hub.
