1 - 4 of 4 Posts
Hi My Name is Kevin and i live in Australia.
I drive a 1979 Z3 and love it. However. I have a problem as my passenger side door will not open. I can lock both the boot and the drivers door using the key, but i cannot open the passenger door from either
- The outside of same
- The inside of same
- The Boot
- The drivers side door
If anyone can help it would be much appreciated.
Great forum by the way.
Regards
kevvy
BMW CCA 1405
1997 BMW Z3 1.9
... passenger side door will not open. I can lock both the boot and the drivers door using the key, but i cannot open the passenger door from either
- The Boot
- The drivers side door...
Perhaps the lock actuator need replacing:
https://www.ecstuning.com/BMW-Z3-1.9-M44_1.9L/ES2634022/
https://www.youtube.com/watch?t=237&v=jroZ1Z9fEv8
http://www.bimmerforums.com/forum/s...lock-actuator-replacement&p=878211#post878211
http://www.zroadster.net/forum/viewtopic.php?t=17528&sid=7cfb2d74166bfab92ee70275d3aaf64f
Discussion Starter #4
stu
Thanks for the quick response. The photos and instructions are well presented and will provide an excellent guide. 1 question i have though is:
After step 5 (remove 3 Large Screws) Will i be able to open the door to proceed to step 6 and (access torx screw under large Rubber seal) as the passenger side door, at present, is locked and will not open at all?
Regards
kevvy
1 - 4 of 4 Posts
