1 - 3 of 3 Posts
I was removing the plastic plenum cover on my 2.8 Z3 and the rubber mount (with a bolt attached) that secures the cover to the valve came off. I actually looks like is broke. If so it is a an extremely clean break. Has this happened to any one else? If so what measure did you take to either repair or replace? Is there a part number listing?
Discussion Starter · #3 ·
So that being said, there is a stud on both ends. one that screws into the valve cover and the other to the plenum cover correct? If so than mine is broken. as part of the mount is in the valve cover and the other in my hand. Any ideas on how to remove the nub in the valve cover. There is no room to get a grip with the ground plate in the way?
1 - 3 of 3 Posts
