1 - 1 of 1 Posts
*Registered Law Breaker*
I need some help and input on this problem I'm having.
I changed out the rotors and pads on my Z, and replaced with Brembo rotors (cross-drilled in the front and regular Brembo's for the rear) and PBR pads for all 4 wheels.
Here is the problem that has arose since changing these out. After driving at high speeds (80-100) on the highway and braking normally, when I drive into my neighborhood and come to a stop the brakes squeal like the pads are low or something. I have taken all 4 wheels off, sanded off any rust, regreased everything and the problem still pops up.
Anyone come across the same issue? Is it because the pads are hot from the high speeds?
Thanks for any help!
1 - 1 of 1 Posts
