I have a 2003 Z4 3.0 and the Hood release is jammed. The release cable has freedom but doesnt seem to move the piece attached to the endpoint of the cable under the hood. It appears that the cable is supposed to pull a metal piece out out of the way, allowing a cam to rotate out of the way and release a larger spring loaded cam that allows the hood to be unlatched. One can see the tension on the line but the metal at the endpoint of the cable doesnt budge, even if you put a metal hook on it and pull it in the direction of the cable. Mention has been made of using a screwdriver to manually release the hood latch but I cant see how based on what I can see of the mechanism. Please advise.
Pete
Pete
