I can tell you what I ordered:
ZFX (Cure Accelerator)
Z2 (Show Car Polish for Clear Coat)
Z5 (Show Car Polish for light Scratches)
Z6 (Quick Detail Spray)
Z7 (Car Wash)
Z18 (Clay Bar)
Z12 (Glass Polish)
Z14 (Plastic Polish)
The Z12 and Z14 are personal preference, but I would definately recommend you get the others.
One misconception that I had was the use of ZFX. I thought you applied the ZFX to the paint and then applied Z2/Z5 over it. This is not true. You actually mix the ZFX with the Z2 or Z5 and apply it. So, you only have to apply one coat. With Z1, the other curing agent, you actually apply a coat of it and then a coat of Z2/Z5. So it would reason that ZFX is a little less work.
Another misconception I had was that you have to use ZFX each time you apply Zaino. That is not true. Once you apply a coat of ZFX (with either Z2 or Z5 mixed in), you can apply the Z2/Z5 up to 10 times without using ZFX. Also, ZFX should not be used more than 03 times in a 24 Hour Period.
What I do is mix about an ounce of ZFX/Z5 and apply/remove one coat. Then apply/remove another coat. Then, the next day or next weekend, I might apply another coat of Z5 and then a coat of Z2, both without the ZFX Additive.
The Claybar really does a great job on the finish. Even on my car, which was only a few months old, I could tell a difference. On my Dad's Truck, it was amazing.
I am also a big fan of the Z6. I use it after each car wash and in between each coat of Z2/Z5.
This is pretty basic, so if you have any specific questions, please ask. I will try to answer them, or maybe the great Zaino King Alee will chime in.:lmao:
**EDIT**
For the record, I ordered my Zaino from
Ecklers. They are a Corvette site, but they ship anywhere and take Internet Orders.
