221 - 240 of 697 Posts
Fantastic!
This is the easiest big fix I've ever done by myself. Every step was so clear cut I thought there had to be a pitfall awaiting me. None! Took me about fifteen minutes. Only hard part was disconnecting electrical wire clip from FSU, but wiggling and pulling worked. I don't even want to know what this would've cost me with my BMW repair guy.
Had same problem.
Had same problem holding down tab with one hand and pulling out the FSU with the other. Not enough room for both hands! The answer for me was to do it with one hand by using pinky to hold down tab and thumb and forefinger to slowly wiggle and pull FSU out. It is slow and almost seems like you're not going to get it, but keep wiggling and pulling FSU while keeping tab depressed and it will come out.
Thanks a bunch!
I've been having intermittent battery drains and thanks to your guide I managed to replace the FSU so thanks. Fingers crossed I won't find myself stranded again :)
I own a 2000 740i (e38) and my blower quits whenever it feels neglected. I was told it is probably the blower motor which is an animal to get at as i think you have to remove practically the whole dash to get at it. I suspect it is the fsu as the cars are almost identical except for the body. Many of the posts for the e39 have worked for my car. Thanks for this post i am going to try it asap. Oh quick stealership story: While in the car was the other day the small grill near my windshield blew off, the plastic pins holding it down must have come out. I went to the dealership to buy these plastic pins, 1/4 the size of a penny thinking they would be $1.00 each at the most. Bmw sold them to me for $4.00 each !!! I found them online for $0.88 each and returned the parts to bmw. :)
Thanks! Worked for me
2000 BMW 528i with 91K miles - cost under 80 bucks for the part from autohaus and took about 10 minutes to switch it out (although it does take some dexterity to get the original one out around the wires).
The fan would go full on or off, not work than go back to normal, thought it was the motor or something more serious. Funny thing was that I just bought the car and the person I bought it from said the shop said it would be ~800 bucks to fix, a really nice surprise that it was this easy. Thanks again!
Man, when I posted this thing, I had no idea it would get this kind of response!
Kind of tells you a few things about how bad this part is. And, still amazed so many mechanics can't recognize it if it's so common.
But--glad to help. :thumbup:
my problem remains with new FSR/FSU pls read on..
My car when running A/C and the fan is lowered less than half it would shut down.
so I researched and found its the FSR/FSU and ordered a new one which is the different design , so it was working fine, but every now and then when the fan control is at its lowest the fan shuts down. I would have to wait 10 mins to cool down the resistor and it works fine after you let it cool. It ONLY happens if the fan blower is set at most minimum at one bar.
Anyone has any suggestion? my new FSR/FSU is a month old ...is this a problem of the automatic controls it self?
I wonder if the FSU is draining my battery intermittently
I finally took the plunge & ordered the BMW E39 Final Stage Resistor from AutoHaus for $72 dollars.
Why did I take so long?
Since most of you said it was "troublesome" to replace the FSU, I didn't want to replace the FSU if I didn't have to.
Plus, the "irregularities" of the interior blower were not major ... just a few wierdities over time, nothing onerous.
But, what's onerous, is lately the battery has been drop-dead dead, about once a month or so, after 8 hours or so of sitting.
I think something's draining the battery 'cuz once I get it jumped, it's fine for weeks. Then, suddenly, embarrassingly, the battery is plumb dead again after sitting for about 8 or 10 hours.
I don't know what's occasionally draining the battery ... but it might be the Final Stage Resistor (FSU) or my recent BMW radio mount DICE Silverline iPod integration.
Tom over at EAS is kindly replacing my DICE Silverline (he's great!) because the DICE is not charging my 2nd-generation iPod touch, so, for now, I'm not plugging my iPod touch in overnight anymore.
Do you think the FSU (or the DICE Silverline) are what's draining the battery?
(PS: I don't see how to measure the density of the battery fluid and that black window doesn't ever show color ... what cruel trick is that?)
I am having the exact same symptoms....
The shop tells me that the battery is fine and the alternator is charging just fine. I have an intermittent parasitic drain on the battery that will drain it down overnight to the point where it will not start the car. I have had it go totally stone dead if left for a few days.
I changed out the FSU (thank you guys for the great instructions..super easy to do) and thought I was in the clear because I went a few weeks without any problems. I had been parking the car in a heated garage and for weeks it would start right up with no problems at all. I left the car outside for the day (20 degrees) and when I went to start it to move it back in the garage... dead again.
Last week I parked it in a cold garage trying to duplicate the problem and it has fired up all week, every time like it had a brand new battery. I know I am on borrowed time and it is going to strand me again but I have no clue as to what is still causing this.
When the car doesn't start, everything is quiet in the car but when the key is turned I can hear the blower motor run.... not wide open but I can clearly hear it running. I just checked and it does this now as well.... and the car started right up.
Any other ideas out there?
Thanks a bunch in advance for your help.
Tim
I don't know what's draining the battery ... but it might be the Final Stage Resistor (FSU) or my recent BMW radio mount DICE Silverline iPod integration.
Tom over at EAS is kindly replacing my DICE Silverline (he's great!) because it's not charging my 2nd-generation iPod touch, so, for now, I'm not plugging my iPod touch in overnight anymore.
Ah, the cell caps are hidden under the pretty stickers!
Can you detect a bad FSU from your OBD codes?
I'm still toying with the idea of OBD II freeware or buying an OBDII tester, especially one that provides real-time data wirelessly to my iPod touch that I connect to the DICE Silverline.
Doing OBDII research, I found this article which implies that you might be able to detect a bad FSU from the OBD2 codes.
Has anyone done that here?
Is this article saying you can detect a bad FSU with an OBD 2 scanner?
Two lessons learned when removing the FSU in the 2002 E39!
It took me about 20 minutes.
It took me MUCH longer than 20 minutes to remove the FSU so that my monthly dead battery would be resolved (I hope).
The instructions here were great. But still it took me almost the entire Superbowl to get the FSU harness connector clip off, and, even then, I ended up breaking one of the sides of the clips to the 2002 FSU.
I concur with post #39 of this thread that it helps greatly to remove the underside of the glovebox (two clips).
I don't know if it's covered in this thread, but, after breaking the clip and examining why, I learned the following:
It is imperative you PUSH inward on the connector (towards the FSU) before you squeeze the clips (perpendicular to the FSU) to unclip!
Otherwise, it will break, like this!
Here are the steps I should have used to remove and replace my FSU
As always, I took pictures but here are the text steps I recommend for removing and replacing the 2002 E39 FSU.
0. Get a flashlight, a #2 Philips screwdriver + a set of 6-inch needlenose pliars
1. Move the passenger seat back & lay the backrest down as far as it will go
2. Lie on your back, hands above your head, ready to work in the foot well
3. Remove the #2 Philips screw holding the passenger left-food kick panel
4. Slide this kick panel straight back (toward the rear of the car) to unclip
5. Slide the underside of the glove box straight back (two clips, no screws)
6. Locate the FSU harness connector and put your pliars on the two "ears"
7. PUSH (this is the important part) a millimeter or less inward, & then unclip
(Note: Step 7 took me all of the Superbowl & even then I broke a clip ear!)
8. Once the FSU connector is off, push on the one FSU connector to release
9. Pull out the old FSU and measure resistance from each terminal to the aluminum fins
10. Measure the resistance of the new FSU's terminals to the aluminum fins
11. As they say, assembly is the reverse of disassembly
12. Test the A/C & air & especially listen for fans after the key is pulled out
RESISTANCE FROM TERMINAL TO ALUMINUM FINS:
#4 #5
#1 #2 #3
pin 1 OLD: 600 K ohm NEW: 11.2 ohms
pin 2 OLD: 3.02 M ohm NEW: 1.22 M ohm
pin 3 OLD: 2.219 M ohm NEW: 608 K ohm
pin 4 OLD: 2.136 M ohm NEW: 602 K ohm
pin 5 OLD: 3.05 M ohm NEW: 1.277 M ohm
It helps greatly to remove the underside of the glove box
It helped greatly to remove the additional underside panel below the glovebox.
This panel slides outward (horizontally, toward the back).
It's held in place with only two clips near the bulkhead and nothing else.
As I said, the big lesson was that the FSU clips were extremely uncooperative but they finally yielded to pressure & persistence (it would have been nice to know the technique of pushing in first before pulling out but I only learned that in hindsight from examining the little tiny lip on the clip ear ends).
Here is the resistance measurement of the old FSU and new FSU for the 2002 E39. It would be of interest to get a database from all that follow us to see if there's a pattern.
I didn't know where to measure between so all measurements are from the terminals to the fins. Notice I arbitrarily numbered them from 1 to 5 in a clockwise direction starting from top left as the FSU was facing away from me. I think pin #1 (bottom left) is the ground pin (do you?).
Does anyone have a suggestion as to what to use to take the old FSU apart so we can have a macabre look inside?
The old FSU is the original aluminum body; the new is black plastic
Well, this morning, on my way to work, the E39 started up perfectly.
No blower wierdities at all ... especially when I shut the car off.
To confirm what others have said, mine seems to have had the original FSU which is the larger cast-aluminum body while the new "Made in Germany" FSU is smaller and has a black plastic body.
Lesson learned .... PRESS DOWN and then press inward to unclip the FSU!
The biggest mistake I made, other than missing the entire Superbowl because it took me a couple of hours whereas I thought it would be done by halftime ... was to not push down on the harness connector (toward the FSU) while pressing the clips inward (perpendicular to the FSU).
As you can see, the method I used was too brutish for the FSU and one ear of the clip broke off.
It was only after examining the clip itself that I realized it has a teeeeny tiny lip of a fishhook on the end, which was the part, I think, I couldn't clear.
