I posted about a month ago about a battery related issue. (I replaced the alternator since then and learned how to check it with the OBC
This car is sitting about 5 days and driven on weekends. It has been dying at the end of that one week time with flashing gauges and now misfiring. The positive terminal is very hot when it dies.
I am now looking at battery drain and yesterday I measured about "1.8 amps" current draw with "everything" turned off other than the trunk being open. (It was daytime and I didn't see the trunk light or figure where the switch was to depressn it..?
Can anyone tell me what the baseline draw should be? ( approx .5 milliamp like some other cars as mentioned in u-tube videos?) So far, I have only checked the trunk fuses and the drain doesn't change. I'm about to discover where the rest of the fruses are inside but it seems like that will lead to a 2 person job or lots of climbing back and forth to the negative battery terminal.
I have read of a few documented draws like the A/C Final something something heat sink and the blower but does a 2 amp draw point to anything specific?
I need to mention there is an mostly not working passeneger seat that I will start with next but it has been in that state a long time before this started...
