Old 04-12-2011, 07:55 AM
JaimeRojas JaimeRojas is offline
Mein Auto: E39
Unhappy 2003 525IT-Smog Failed
Took the car for smog inspection- and failed... Technician suggested I change the MAS to begin with. I did, now however; my CEL is on and DTC's are as follows: P0313 -Misfire Det. w/low fuel, P0175- system too rich (bank 2), P1343- Manufactured specific code, P0172 - sytem too rich (bank 1), and P0102 Mass or Volume Air Flow Circuit Low input.
Is this a sign that my sensors are bad? Does anyone know what I should begin with.
Old 04-12-2011, 08:35 AM
Takechan Takechan is offline
E39 fanboi
Mein Auto: BMW E39 520i (M52B25)
Check for vacuum leaks and the MAF. The rest "might" go away if you fix that.
Old 04-12-2011, 10:02 AM
You 'might' find hints in this (still nascent and unfinished) thread:
- How to diagnose a typical BMW E39 engine misfire (1)
That thread, which is a summary of scores of misfire threads, has all the culprits nailed down; but it still needs a lot more on the diagnostic side.
In addition, to the OP, please post your smog results to this thread:
- Please post your E39 emissions smog test results
Old 04-12-2011, 01:02 PM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
Check for vacuum leaks. Buy a small propane tank, and run a long hose off the end; open the valve just slightly, and hold the hose over vacuum components one at a time. If your idle changes, you have found your leak.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 04-12-2011, 01:33 PM
I'll add that to the misfire thread ... but ... may I ask ... (a serious question).
Q: What happens if there is an inadvertent spark while the engine is running?
Does it just 'puff' and go away or is there a boom?
Old 04-12-2011, 07:39 PM
There is no source of ignition under the hood, and even if there was, the amount of propane is very small so nothing will happen. One of my friends is a factory trained tech, and he told me this is the method the dealer uses.
