Old 04-09-2008, 08:13 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Z3: IE Rear Toe/Camber Install
I spent last week doing some upgrades one of which was installing the IE toe and camber adjusters.
I had the alignment checked late last year and found some significant differences from side to side.
First step was to drop the rear subframe and suspension. Built a frame to support the subframe while it was out of the car. This allowed me to understand the amount of adjustment as I created the slots for the adjusters.
I then started to create the slots required for the excentric bolts to move in.
The inboard mounts will adjust the Camber and the slots run Vertically.
The outboard mounts will adjust the Toe and the slots run horizontally.
I used a round file and a air powered die grinder to create the slots.
The vertical slots started from the stock location and were opened upwards.
The horizontal slots would normally be centered on the stock location but I made them more to the front as I had toe out problems.
Once the slots where the correct size to allow the bolts full range of travel I tacked the supplied plates into place and test fitted the control arms.
Both bolts, on each arm are inserted from between the two mounting points.
This showed some issues with the initial placement of the plates so I removed and re-tacked the affected plates.
I took the subrame to a local shop to have the plates welded into location and then painted the subframe before re-installing.
The IE subframe bushings required to have a small section removed to allow the outside nut's to be fitted.
I also had to remove approx 1/8" from the large washer at the top of the two bolts that locate the subframe. Otherwise the new bolts would contact the washer and stop the subframe locating correctly.
I still have to take the car for a full alignment but it's looking good so far.
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 04-09-2008, 08:55 PM
Randy Forbes's Avatar
Investigative Tinkerer
Nice job, and good idea about the test fixture, you proved it was worth the effort.
Randy Forbes
2001///M Rdstr Steel Gray
Old 04-09-2008, 09:38 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
Looks familiar.
I put the outer bolts in from the outside so I didn't have to trim the Ireland bushings; the bolt head is short enough that it didn't conflict on my car. Very close, but it fit.
Daniel
2002 M roadster
Old 04-09-2008, 09:53 PM
TurnAround TurnAround is offline
Mein Auto: Z3C, Z3R, X5
1st: Will you do my Coupe next please?
2nd: Holy shiit you're brave and talented.
3rd: For those of us that have replaced our springs and shocks and understand the basics of the factory hard set camber welded in subframe, but not the subtleties of the fabrication needed to correct BMWs short cuts, I'm confused by something. Are you saying that IE offers an eccentric bolt and bushing kit? Then why did you need to also create the inboard camber slotting and the outboard toe slotting?
I'm interested in eccentric kits.. that work and hold... but am concerned about weld in options like Dinan, etc.. I live in more or less bubba-ville. "Goofy's Mufflers" are considered the resident welding experts. How could I take my Coupe there?!
'02 Z3 Coupe 3.0i [Hellröt II - Walnuß]
'03 X5 3.0i [GrauGrün - Beige]
'01 Z3 Roadster 3.0i [AlpenWeiß - TraumRöt]
Old 04-10-2008, 07:00 AM
There are two IE products involved in this mod so that may have caused the confusion.
IE subframe bushings - these are a common mod.
IE "weld in" TOE/Camber kit.
The bushings replace the stock rubber bushings to stop the subframe moving so much.
The IE TOE/Camber kit consists of a set of bolts (with excentric washers) and metal plates that are welded to the subframe.
See the 4th picture in the post.
The excentric bolts allow cause the location of the bolt to alter depending on it's orientation.
Moving the inboard mounting point upwards causes the wheel hub angle to change and the Camber is reduced.
Moving the outboard mounting forward changes the toe to make the wheel point towards the middle of the car, moving it backwards causes the wheel to point out from the car.
Here is a quick diagram. The top picture is looking down on the "car", the bottom picture is looking from behind the "car".
Old 04-10-2008, 07:48 AM
Ok.. now I'm getting it on the mechanics of how the eccentric is working. Thanks.
So you're saying that the only normally required part is slotting the existing mounts on the subframe, but that what you did differently was to have the cars alignment checked first so that you knew more precisely what your toe situation was, and you then slotted the outers a little more forward than "both ways off of center". Very cool. Smart.
When a stock Z3 is lowered via springs, does this equate to causing more toe out (kinda like lowering equates to more negative camber no matter what). If true.. my now lowered Coupe will not only wear tires faster because of the added negative camber, but because I have more toe out??
I haven't taken the car in to have the alignment checked yet. I don't know what the stock numbers (range) should be. Do you by chance?
The grinding would be within my capabilities, but I have no welder to tack with (hmm... a neighbor does though). But mainly, I think the removal and installation of the subframe and diff and drive shaft are way over my head. How much would this kind of work cost if I had it done?
Thanks.
Old 04-10-2008, 08:57 AM
I've seen estimates from $300 to $600 to drop the subframe and install IE bushings.
Expect another $100 for the welding, and another $300 to $600 for the work to slot the subframe and install the IE parts.
Throw another $100 for the alignment and your looking at between $800 and $1400
Stock Rear alingment specs I have are
Camber -1.3 to -2.3
Toe 0 to +0.5 (with Positive = wheel point inwards and negative = wheel pointing outwards)
My specs before were
Left Camber -1.1
Left Toe -0.11
Right Camber -2
Right Toe -0.68
Old 04-12-2008, 03:29 PM
Just got back from the alignment shop and everything is back within spec at the rear (even with the car lowered 1")
Left Camber -1.9
Left Toe 0.09
Right Camber -2.1
Right Toe 0.1
Toe adjustment range was -0.7 to +0.5
Camber was over a deg as well.
Old 04-12-2008, 05:15 PM
Left Camber -1.9
Left Toe 0.09
Right Camber -2.1
Right Toe 0.1
Excellent work. I'm envious.
So.. did you manually align the camber and toe on your hand made rack, and you're saying you hit those numbers (only used the alignment shop to get a reading)? Or, once you had it at the shop did they get under there and adjust the eccentrics?
Old 04-12-2008, 05:36 PM
FredR FredR is offline
Mein Auto: 96 BMW Z3, 97 BMW M3
Great Job!
I did this a couple of years ago. Best thing I ever did to the Z. I started out with a new crossmember, kinda expensive but I knew it was not bent in any fashion. I had over 3 degrees of neg camber with stock springs and we got it back to a degree. I'm to old and fat to do this on jack stands so I sub- contracted the fix. Cost w/o the new crossmember was $1400. I did replace the trailing arm bushings w/ stock as well. Why BMW didn't do this from day one is a mystery to me. It would have cost them maybe $1.50 a car and think of all the grief it would have solved.
96 Z3 1.9 Black/tan/black
97 M3/4 Estoril/dove gray
08 3400HST Kubota Orange/gray
08 GMC Sierra CrewCab
Old 04-12-2008, 05:58 PM
I used the rack to get a good idea of how much movemen I was getting as I created the slots and also to make it easy to put the RTA's back on the subframe to make sure the adjusters etc were in the correct locations.
Once the car was up on a lift it was easy to adjust both the toe and the camber. I was worried that the exhaust may get in the way but the only thing I needed to do was removed the two plastic parts that sit on the top of the subframe to hold the speed/brake wear connetors.
The biggest problem we had with the alignment was the "beam" across the front car.
We had to take the plastic under engine shield off and use a jack to "tweak" the front spoiler up just an 1/8" to make sure the sensors could see each other. This was with the fron lowered 1" front stock.
He had a Hunter 611 alingment machine.
Old 04-12-2008, 06:10 PM
If you go to the KMAC web site (they make an eccentric bolt kit) and hit their car brand and model drop down you get.. basically every car built in the world since 1988. As they cover on their site, every car maker in the world "went cheap arse" on their consumers some time in the 80's. NONE of them have front and rear camber adjustment, rear toe, or front caster. THe only thing you can adjust is front toe... in case you hit a curb and bend a steering arm.
It is very disappointing that BMW followed along with this trend.
Here is something interesting though. I just found out 3 weeks ago that my 2003 X5 actually has rear camber and toe adjustment. Simple, easy, lock down effective. So apparently they've started to get smart again. This, of course, does me NO good at all, because I lowered my Coupe but won't necessarily lower the X5. Doh!
Old 04-12-2008, 06:19 PM
Thanks for the explanation. This is all helping.
I think I could actually do this.. with the help of this guy I know. He has a large shop and a full lift. I haven't talked to him in a few years though. Kind of a recluse. Retired. But.. how could he say no, right? He's got to be bored.
I'm gonna post about another front camber issue in a minute here. It would be great if all you guys could read it and comment. You have the experience level I need access to.
Old 04-13-2008, 01:20 PM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
E46 M3 has camber and toe adjust front and rear.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 04-15-2008, 09:07 PM
phrider's Avatar
phrider phrider is offline
Equine 1/4 miler ancestor
Mein Auto: 2001 M Roadster, 1998 M3
Edge Motorworks in the SF Bay area has good luck with the AKG bushings vs the KMACs.
See the discussion at http://forums.bimmerforums.com/forum...9#post12510699 starting with comments by Nivola.
http://www.akgmotorsport.com/
Old 04-17-2008, 01:45 AM
windnsea00 windnsea00 is offline
Mein Auto: 997 Carrera S
How do you adjust the camber on the front of a stock E46 M3?
Old 04-17-2008, 08:35 AM
Pinecone's Avatar
M Mad
Pull the alignment pin and just the slotted strut tower. You can go about 0.5 degrees each way. Most poeple go an extra -0.5 degrees. It is really there for crash damage adjustment, but no reason you can't use it for general alignment.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 08-03-2008, 09:07 AM
Car54 Car54 is offline
Mein Auto: 325i, Mcoupe, Titan
Does it matter if the welded in pieces are exactly vertical or not? Does the kit come with other instructions? Do you make your horiz and vert slots perpendicular and parallel with the ground when the subframe is in the ground?
Sorry to dig this up, but AWESOME post!
2010 BMW 550iGT
Old 08-04-2008, 07:43 AM
Very limited instructions. not much more than one veritical and one horizontal slot.
Obvoiusly the closer you can get them to true horizontal and vertical the better but a slight variation is not an issue. The important thing is to have an alignment done before install so that you can select to bias the slots in the right direction to get the most adjustment when installed.
e.g. I had toe out so I made the slots for that as far to the front as possible.
Old 08-04-2008, 06:56 PM
How do you know which tabs to H and which to V?
I plan to be putting this together with a new subframe and one new trailing arm, so my alignment will be obsolete. Would you say I just split the difference from the center?
2010 BMW 550iGT
Old 08-04-2008, 08:04 PM
Another question, do you have to pull the half-shafts from the diff?
2010 BMW 550iGT
Old 08-04-2008, 09:25 PM
dwm's Avatar
dwm dwm is offline
Horizontal on outboard brackets (near subframe mount points) for toe, vertical on inboard brackets for camber.
Yes, that will work fine (it's what Randy and I did on my car).
Daniel
2002 M roadster
Old 08-04-2008, 09:27 PM
dwm's Avatar
dwm dwm is offline
It depends on how you want to remove the subframe. I take the whole thing out at once with the differential still attached. Others remove the differential first.
Daniel
2002 M roadster
Old 08-04-2008, 09:30 PM
Ron Stygar's Avatar
19,585 Miles
Looks nice.
Old 08-05-2008, 09:50 AM
I took the whole rear end out as a single section. Then remove the crossmember from the diff and trailling arms.
