My Windshield Washer RESERVOIR Leaks a bit at the Filler Neck (where the Tubing joins the Reservoir), so I decided to freshen things a bit! If your Windshield Washer has been leaking, the good news is all this can be fixed for approx. $10.
Expanding Rivets x 3: PN: 51478166992 ---> $0.66/each
Grommet w/ Strainer: PN: 61667006063 ---> $4.24/each
Grommet: PN: 61311369343 ---> $3.13/each
It can leak at the:
- Filler Neck (where it enters the Reservoir)
- Windshield Motor
- Level Sensor
Time: 1 hour.
PROCEDURE:
1. Passenger's Front Wheel removed, car on Jackstand.
2. Remove the Plastic Wheel Liner. I did it the "lazy" way and lift it up just enough to do the job.
- 8-mm screws hold the Plastic Liner.
- The three (3) "Expanding Rivets", don't even try to save the old rivets, they break when coming out, using a flat screwdriver and gently lift it out, and cut with a pair of snippers.
3. Using a Flat Screwdriver, gently lift the Windshield Fluid Motor UPWARD (Yellow arrow).
4. The Level Sensor comes STRAIGHT out (Yellow arrow).
5. Remove the two (2) 10-mm Nuts holding the Reservoir and remove it for cleaning. My fine mesh screen broke from the rubber grommet and was inside the Reservoir. Easy to remove it. Then rinse the inside the Reservoir and empty all water.
6. Tips when re-installing new parts:
- Tiny amount of grease on the Filler Neck for a good seal. Factory has no zip ties. Mine leaks right here, so after a bit of grease (very thin smear) and 2 zip ties, it is nice and tight, no leak!
- Tiny amount of grease (very thin smear) on both grommets.
- Tiny amount of grease for the Expanding Rivets makes it easy as well.
Congrats on a job well-done and now you have a leak-free Reservoir!!!
It can leak at the:
- Windshield Motor
- Level Sensor
Time: 1 hour.
PROCEDURE:
