So here is the start of a long project. I got the car with a blown auto/slushbox for 500 bucks with a perfect enigne.:thumbup:
In regards to the cruise control. I don't think there is an easy way to make this work, the cluster is telling the cc module the car is in park, and the module says ok, well it doesn't make sense to use me in park. Last time I looked at the wiring, I didn't think it was a simple power or ground wire telling the cruise this, but its been a long time so I may be wrong.Onto the wiring!!! This is pretty simple.You'll want to pull the #6 pin brown wire from the blue 6pin plug and put it in the place of the #10 pin silver wire from the black 12 pin plug. If Im right this shuts off the trans failure code. Next up is the 8 pin plug. From here you take the GREEN/RED wire and splice it together with the BROWN/BLACK wire and you can now start your car as the computer thinks the car is in park. Now for the reverse lights. From the same 8 pin plug your going to splice together the wires from your reverse switch on the tranny to the GREEN/BLACK wire and the BLUE/YELLOW wire and you now have reverse lights and the passenger mirror should also tilt. I have not had time to mess with the cruise control yet but as of now the car is done. Im just trying to find the time to upload everything that Ive done to the car, I did most of the swap this last saturday and spent another 15 hours on the car yesterday
. So coming up next is the clutch lines and random repairs on the car.:thumbup:
This is what the clutch switch is for, and the wiring IS already there. The cruise won't even activate if it thinks the car is in Park though. It MIGHT work if you hack it to think the car is in neutral, but then I think something else like traction control or something breaks. I don't remember all the details.No I didnt bother looking for a manual DME as its not needed cause my car is obdI and if it was obdII my brother could reprogram all 7 modules in the car as he did on his car. Also I just drove the car and it runs FANTASTIC!!! Not as torquey as my brothers E39 540i wagon also converted to 6 speed but still its pretty quick. As for the cruise control. Yah I got the clutch switch but I couldnt find a loose cable anywhere. Its prolly just hiding somewhere. I saw a guy that converted a 740il said you just needed the clutch switch to shutoff the cruise control when you pushed clutch in so the revs wouldnt start racing.:dunno: I need to try it and see if it even works. If not I can get the whole wiring diagram from my friend in Sacramento that runs a very high-end BMW shop and just track down what needs splicing where.
Dead on correct, as stated previously in another thread. It actually gets pretty annoying pretty fast if you ask me. A manual tune with a bit of a timing bump is worlds better drivability wise.RESPECT.
Comments.
1)I've ran both an auto and a MT tune on my 6 speed. The auto tune is fine but the MT tune actually is better.
They hold back some timing for the automatics to hold the torque curve back a little to protect the weaker auto trans.
Also when you shift or let off it allows the revs to hang a little ive noticed.. Has other Weird little characteristics.
